PS3 not finding nor playing m4a files
A few nights ago, i attempted to play a folder which had 12 m4a files in it on my ps3, when i clicked on the folder, it came up on the screen "There are no tracks" i tried several other folders which had m4a files but the same message came up on them all. I am running the current version 6.5.0.
I decided to uninstall the new version and do clean installs of older versions to see were this problem started from as i have had no problems playing m4a files before, the last version that displays m4a files is version 6.0.0 every version since has the same problem.
I am using the Windows java 7 version of UMS, i am running UMS of a Windows XP SP3 operating system, if you need anymore information please let me know.
Trace Log attached from version 6.5.0
Dave
Dave
- (37.25 KiB) Downloaded 486 times
Re: PS3 not finding nor playing m4a files
Can you post the result of following?
- Remove track "02 - Keith Urban - John Cougar, John Deere, John 316.m4a" from tests
- Post mediainfo for the same track
