Can anyone help me transcode x265?
chamelious
Post by chamelious »
When trying to some transcode x265 i noticed nothing would happen for a few seconds then it'd kick me out saying "please check your network connection". I've tested this now on non x265 and i#m getting the same problem; i can't transcode anything. Can anyone advise what i might be doing wrong?
Note: Cannot attache debug files as they exceed the maximum attachment size.
squadjot
Re: Can anyone help me transcode x265?
Post by squadjot »
Its hard to say when you provide no real info about the problem.
If you can't upload debug files to forum use http://uploaded.net as suggested in the "Problem reporting guidelines"
squadjot
Post by squadjot »
Yes, now a developer can have a look at it and probably help you. Thanks
valib
Post by valib »
Try to make a default video files transcoding engine the FFmpeg not Avisynth/FFmpeg if you don't have any special need for it. It seems that it is not working properly also for me.
