Sony 4K 55x855D: run only 2 minutes video
Runs only two minutes of video and stop. I believe it is something related to file size as they are little more than 2minutes to 1080p and just over 4 minutes to 720p. Sending log file.
- print.JPG (74.72 KiB) Viewed 13843 times
- (90.91 KiB) Downloaded 828 times
Re: Sony 4K 55x855D: run only 2 minutes video
Can you try enabling chunked transfer in your conf?
For devs: UMS is sending incorrect content range. A subsequent try to read the end of file returns invalid response and hence renderer drops the connection.
ChunkedTransfer = true
TRACE 2016-09-02 19:54:58.226 [New I/O worker #6] Sent to socket: TransferMode.DLNA.ORG: Streaming
TRACE 2016-09-02 19:54:58.226 [New I/O worker #6] Sent to socket: Content-Type: video/mpeg
TRACE 2016-09-02 19:54:58.226 [New I/O worker #6] Sent to socket: Content-Range: bytes 0-9223372034707292158/9223372034707292159
TRACE 2016-09-02 19:54:58.226 [New I/O worker #6] Sent to socket: ContentFeatures.DLNA.ORG:
Did not work. The same problem persists. Wheel for a certain time and stop.
I just bought pretty similar model I think .. KD-55XD8005 .. maybe I am blind but I can not figure out where to start playing media server files. I noticed UMS is recognized in settings/media servers ... anyone with Sony Android and can help a fellow earth citizen, thanks
Nevermind, found it. It's the VIDEO app on Home menu
I have the KD65-XD7505, is UMS working for you ? for me videos list appear but when i launch one only have a black screenhuulio wrote:I just bought pretty similar model I think .. KD-55XD8005 .. maybe I am blind but I can not figure out where to start playing media server files. I noticed UMS is recognized in settings/media servers ... anyone with Sony Android and can help a fellow earth citizen, thanks
I just get the spinning circle. I tried Plex and Kodi .. both of these do work with the tv.AlGrenadine wrote:I have the KD65-XD7505, is UMS working for you ? for me videos list appear but when i launch one only have a black screenhuulio wrote:I just bought pretty similar model I think .. KD-55XD8005 .. maybe I am blind but I can not figure out where to start playing media server files. I noticed UMS is recognized in settings/media servers ... anyone with Sony Android and can help a fellow earth citizen, thanks
Though with Kodi I seem to have some sort of cached list.. no matter what I do I can't get the tv to refresh my folders.
- Huulio
Anyone using a Sony telly with Android OS .. download VLC for Android.
Just did number of tests and it plays everything with UMS, unlike the crappy internal media player.
- Hool
- Hool
