No video supported format and MME type Found
I came across two videos in which I cannot play. It returns with "No Video Supported format and MME type found" attached is a screen shot and log files for your review. I noticed that if i disable subtitles the videos in question play just fine.
I have uninstalled UMS twice and disabled MEncoder as per older threads with similar issues however no luck.
OS: WIndows 10 Pro
Browser: FireFox v 48.0.2
any help is greatly appreciated
Kind regards,
OS: WIndows 10 Pro
Kind regards,
- FireFox_Video_Suppported.png (695.64 KiB) Viewed 5960 times
- (61.43 KiB) Downloaded 545 times
Re: No video supported format and MME type Found
Transcoded files don't play well on browsers. Any UPnP renderer would play them well however.
Note: In your case, file is being transcoded because that's the only way subtitles can be supported for browser.
Thanks, your right when i play these movies on a renderer such as BubbleUPNP or Chromecast the subs and movie play just fine.
