Version 2.6.3 is released
Post by SubJunk » Wed May 01, 2013 9:37 am
General:
This release improves detection/connection to renderers, improves AAC/M4A support and updates external components
Changes since 2.6.2:
  • General:
    • Improved detection of renderers
    • Improved AAC/M4A support
  • External Components:
    • Updated Apache commons-lang to 3.1
    • Updated thumbnailator to 0.4.3
Upgrade Notes:
For versions prior to 1.5.0:
For all versions:
It is recommended (but usually not necessary) to delete your UMS.conf file prior to installing this version. Windows users can choose the "clean install" option while installing instead.
The PMS developers
darkmenace
Re: Version 2.6.3 is released
Post by darkmenace » Wed May 01, 2013 11:38 am
Auto updater failed on Windows 8 this is the second time this has occurred. It goes through downloading the file then fails to launch update saying you may have to download it manually...
Post by SubJunk » Wed May 01, 2013 1:44 pm
Make sure the program is running as administrator before running the updater
Mandabar
Post by Mandabar » Wed May 01, 2013 5:20 pm
Running 2.6.2 and it is unable to auto update (Yes in Administrator mode) to 2.6.3. It goes and downloads the whole shebang, and then errors out.
Last update I had to manually update as well. Unsure what version it was from, but it was upgrading to 2.6.2.
Running Java
C:\Users\Mandabar>java -version
java version "1.7.0_02"
Java(TM) SE Runtime Environment (build 1.7.0_02-b13)
Java HotSpot(TM) 64-Bit Server VM (build 22.0-b10, mixed mode)
Optimus_prime
Post by Optimus_prime » Wed May 01, 2013 6:52 pm
OS-X Build is up on Sourceforge
darkmenace
Post by darkmenace » Wed May 01, 2013 11:40 pm
Same here running as Administrator has done it not for 2.6.1 - 2.6.3 just haven't had any free time to login and report it. Thought it was a fluke the first time but now that it has happened again I figured I best report it.
Post by SubJunk » Thu May 02, 2013 9:00 am
I just tested and it works for me. Feel free to start a thread for it on the help section if you want
tachyon
Post by tachyon » Sun May 05, 2013 12:54 am
Do you have any plans to implement ffmpeg_video_custom_options (from PS3 Media Server 1.80.0)?
Post by SubJunk » Sun May 05, 2013 10:56 am
Sure, if you want it :)
