Can't Access Recently Played Folder (Fixed)
So, not a support request but I wanted to make sure the community had the information. Running UMS 6.5.1 on Windows 10 x64 with 32GB of RAM. I used the Recently Played folder just to see what I last watched. However, when browsing it this morning, I received this error:
DLNA 2114 Error
I couldn't view the contents. I checked the contents of C:\ProgramData\UMS\data\resume and it was showing the information in it as well as new data but not on the media server. I had been working with interface metrics on my computer (multiple network connections and prioritization) and, after done, I would have to re-bind the correct interface to the software. This "could" have caused issues or corruption of some sort. In any event, I ended up backing up the C:\ProgramData\UMS and the UMS.conf file and doing a fresh install. I then put my UMS.conf file and the \resume and \data folders back in the C:\ProgramData\UMS directory and started UMS. This worked. It is not only showing the data but it is updating with new data as well as showing the resume options in the directories of the media, themselves.
For a previous history I've had with this feature, see here:
viewtopic.php?f=9&t=3381&p=16365
I hope this helps others.
DLNA 2114 Error
