[Suggestion] Excludes for Cache Database
it would be cool to exclude path/folder from the cache database.
For example: a checkbox on each path entry under "shared folder" to select or deselct path/folder for the cache database.
this feature can be used to exclude optical drives from the database management (no need to add content for optical drives) of any other path/folder you dont want to have in your cache database.
thanks
Dosa
thanks
Dosa
Re: [Suggestion] Excludes for Cache Database
I believe the new feature "Advanced Monitoring" is for this reason, it'll detect new content and actively update that location.
@Subjunk right?
@Subjunk right?
Universal Media Server Wiki!
