Auto update
Auto update
Updating manually is not a big pain, but automatic updates would be so nice.
Re: Auto update
there is a option but its not turned on by default on the general settings tab of the ums its the next tab after logs you can take a look on the settings there is one called verify automatically for updates or check automatically for updates something like this.
i hope it helps.
i hope it helps.
Re: Auto update
Oh, didn't notice that!
Unfortunately, they're greyed out for me (maybe doesn't work for the Linux version?)
