Philips TV problem
Smog
Philips TV problem
Post by Smog »
HI! UMS see the tv, but the tv don't dee UMS... UMC is last version, I will be grateful for advice.
(31.73 KiB) Downloaded 442 times
Sami32
Re: Philips TV problem
Post by Sami32 »
could you try with this new configuration file and return your new TRACE log.
Philips-TVSmog3.conf
(2.49 KiB) Downloaded 441 times
As i never see this kind of renderer before, the specification are hazardous, at best, but since it's for recognition purpose...
You need to place this file in the "renderers" folder, inside you "Universal Media Server" install directory, with all the others renderers configuration files.
Smog
Post by Smog »
Here is the new debug file. The picture are different and looks like my old tv ...
NEW_ums_dbg.zip
(28.3 KiB) Downloaded 433 times
Sami32
Post by Sami32 »
DEBUG 2017-01-08 22:14:44.155 [AWT-EventQueue-0] Failed to open default desktop application: java.io.IOException: Failed to open C:\Program Files\Universal Media Server\renderers\Philips-TVSmog3.conf. Error message: No application is associated with the specified file for this operation.
You did something wrong...
Until you see "Philips TVSmog" appear here in your log, try again.
INFO 2017-01-08 22:13:42.416 [main] : Philips Aurea
INFO 2017-01-08 22:13:42.416 [main] : Philips TV
