Samsung C/D Series
Samsung C/D Series
This is a first time for me to write to your team....I just hope that I'll be able to report the problem correctly.
The problem exist since the version 6.5.2 and I just try 6.5.3 and still the issue present. It will or not steam the video, when it does work after 30 to 45 sec. of waiting I can't go forward, backward or to go to a specific point with in the video. The time frame is incorrect it is not in hours minute look more like only seconds.
Hope that the attachments will give you a clue of the issue.
I'll stay will the version 6.5.1 that is working find with all video that I have at moment.
Regard,
Normand
Regard,
Normand
- ums_dbg 6.5.1.zip
- (707.24 KiB) Downloaded 370 times
- ums_dbg 6.5.3.zip
- (859.01 KiB) Downloaded 388 times
Re: Samsung C/D Series
To add on, I believe this issue all ready existed and was fix on the follow version.
Version 5.1.1.1 for Windows is released
Quote
Postby SubJunk » Mon Apr 06, 2015 5:08 pm
General:
This is a Windows-only quick fix which corrects the 32-bit MediaInfo dependency.
Changes since 5.1.1:
• General:
◦ Fixed MediaInfo dependency
Quote
General:
• General:
Hi Capiray,
Thank for reporting.
Could you post the MediaInfo infos file for this movie: Ice Age 2 The Meltdown 2006 MULTi VFF 1080p HDLight x264.GHT (L'Âge de glace La Fonte).mkv ?
I saw 2 UMS issues in your log:
The H.264 level is unknown, and it should be, so it give you the transcoding issue that you are experimenting.
TRACE 2017-01-07 14:43:08.285 [ffmpeg.exe-11-Timer] net.pms.io.BufferedOutputFileImpl buffered: 239,500,000 bytes / inputs: 0
DEBUG 2017-01-07 14:43:08.971 [ffmpeg.exe-11-Cleanup] net.pms.io.ProcessWrapperImpl Stopping process: ffmpeg.exe-11
TRACE 2017-01-07 14:43:08.971 [ffmpeg.exe-11-Cleanup] net.pms.io.BufferedOutputFileImpl Destroying buffer
DEBUG 2017-01-07 14:43:08.971 [Thread-65] net.pms.io.WindowsNamedPipe Error: null
Hi Sami,
Has requested here is the info.
See attachment.
Regards,
Capiray.
P.S. Let me know if you need me test more files.
See attachment.
Regards,
Capiray.
- Ice Agen Collection.jpg (99.77 KiB) Viewed 5868 times
Hi Capiray,
Thank for the informations
Let's see what ca be done...
