Philips Android TV PUS6561/12 not showing any file
grabo
Post by grabo »
Hello i bought and android tv - philips pus6561
UMS server is visible in device list but there is no file.
debug file in att
(39.84 KiB) Downloaded 1268 times
Sami32
Re: Philips Android TV PUS6561/12 not showing any file
Post by Sami32 »
In the "General configuration" tab, from "Select renderers" deselect all the renderers except the "Philips TV".
BTW, renaming your TV name as you did, "TV salon" instead of the default "Philips TV", could give you some UMS recognition issue.
And replace that renderer by this one:
Philips-PFL.conf
(9.09 KiB) Downloaded 2317 times
Please, don't forget to return feedback, and log, as this should only a premisse to solve this issue.
Andreasryden1980
Post by Andreasryden1980 »
Well, the TV is Android and UMS have hard to recognice the tv.
Either it Thinks its a Philips TV or a Android unit.
I have modified the philips config file, and this one works on my Philips PUS8809.
I saw that the user above me have attached a config file, but that one didnt work on my TV.
So if that one didnt work on your, you can try mine.
Just copy and replace you original file
Philips-PFL.conf
(9.78 KiB) Downloaded 1948 times
Galo
Post by Galo »
Hi, guys. Can someone of you edit this configuration file for my Philips PUS6561/12? If it possible to add subtitles support? Thanks in advance.
edit: Hi, again guys. I solved subtitles issue, it was my mistake with settings in UMS. Now I have another issues, hope you can help me to solve them too. When streaming video and subtitles are enable, audio is only 2 channels (stereo), when disable subtitles is 6 channels (5.1), also i can not rewind and seek forward. I try almost everything, but without any success. Without transcoding everything is fine with audio and other functions. Can you help me to solve this issues? Kind regards.
(Sorry, I know that my english is not very good, I hope you will understand me)
Philips-PFL.conf
(9.78 KiB) Downloaded 1615 times
OzzY
Post by OzzY »
Andreasryden1980 wrote: Fri Mar 03, 2017 9:02 am Well, the TV is Android and UMS have hard to recognice the tv.
This conf.file for Philips one also worked for me with PUS7502... But I can not use it to watch DVD-images.., but for mkv it worx
CureMar
Post by CureMar »
Galo wrote: Thu Nov 30, 2017 8:15 am edit: Hi, again guys. I solved subtitles issue, it was my mistake with settings in UMS.
Hi, could you tell me what did you do? I have the same problem with Philips Android TV.
valib
Post by valib »
Galo wrote: Thu Nov 30, 2017 8:15 am I solved subtitles issue, it was my mistake with settings in UMS. Now I have another issues, hope you can help me to solve them too. When streaming video and subtitles are enable, audio is only 2 channels (stereo), when disable subtitles is 6 channels (5.1), also i can not rewind and seek forward.
In your conf you introduced
StreamExtensions = mkv,hdmov,hdm,flac,fla,dts,ogg,asf,asx,m2v,mp4,mpg,mpeg,avi,mov,wmv
and deleted
MediaInfo = true
which means that all following "Supported" lines are ignored. There are not subtitles enabled for streaming which means that video with external subtitles will be transcoded and that is why the transcoded video has only 2 channels audio and you have problem with rewind and seek forward. I don't know if your TV support streaming subtitles but you can try to add
SupportedExternalSubtitlesFormats
to enable subtitles streaming. The description is in the DefaultRenderer.conf
# A comma-separated list of supported text-based external subtitles formats
# for streaming together with streaming (not transcoded) video.
#    Supported formats:   File extension:
#    ASS                  .ass or .ssa
#    MICRODVD             .sub
#    SAMI                 .smi
#    SUBRIP               .srt
#    TEXT                 .txt
#    WEBVTT               .vtt
# Example: SupportedExternalSubtitlesFormats = SUBRIP,ASS,MICRODVD
# Default: ""
Dasix
Post by Dasix »
CureMar wrote: Thu Jun 14, 2018 10:03 pm
I also would like to know the answer, I got my TV to stream all my contect except it doesn't shows any of my .srt files and I can't make it work.
I'm pretty sure my TV supports subtitles as sometimes it gives me to option to choose english, with files I don't even have english subs (possible snatching it from opensubtitles.org?), but I want my hungarian .srt files to work.
Also if I want a proper conf files can someone make me one for my 49PUS8503?
I don't know how to, and this might be the problem as I literally tried everything in the transcoding settings.
Thank you!
Hi Dasix, please post logs so we can see how to identify your TV
Andreasryden1980
SubJunk wrote: Tue Oct 30, 2018 8:18 pm Hi Dasix, please post logs so we can see how to identify your TV
I got the same problem.
I dont now if its because newer Philips TV got a real updated Android OS now, and not a mix of OS like it used to be.
I tried many configurations on my Philips Oled 873, and nothing works.
It can show burnt in subs, but not external.
The info says Subrip, but nothing appears.
I have tried to force renders, like Android, cromecast, xbmc, etc and nothing works. It shows the Movie but not external subs.
I tried to force render: Samsung-9series
Then it shows the Movie for about 3 seconds with external subs, and then it crashed.
Even the program Serviio dont show subtitles anymore with newer Philips Android tv.
It works on older Philips like 8809, but they are on older Android, like 6.0
Edit: Also.
Some got problems that no files can be showed in the media tree.
The solution it to rmeove the line:
MediaInfo = true
If that one is remowed, the files will be visable again.
