Running time.
Chalkiejim
Running time.
Post by Chalkiejim »
I am using a Samsung smart TV to play media from UMS. Up until version 6.5.2 everything worked fine. Since then version 6.5.2 and 6.5.3 have been showing incorrect running times on the TV screen. Rather than showing 1:35:00 for instance and counting down it just constantly shows 999:59:59 and stays the same. I have reinstalled version 6.5.1 now and all is back to normal. Please could this bug be fixed so I can use the latest version of UMS. I have uploaded my bug report for this issue. Many thanks.
(50.64 KiB) Downloaded 516 times
Sami32
Re: Running time.
Post by Sami32 »
Is it happening only with your MP4 video files ?
Do playing the files from inside the #--TRANSCODE--# folder give the same result ?
Chalkiejim
Re: Running time.
What a great question. So I've done some testing. All of the MP4 files were showing the wrong running times, so then I tried the AVI and MP3 files. The AVI and MP3 files were showing correct times. What I did find was, the MP4 files were running through the transcoder and the AVI and MP3 files weren't. So I went into the transcode folders and ran the MP4 files without it being transcoded and BINGO, the running time was showing correct. The transcoder being used was the FFmpeg. There must be some sort of conflict between the transcoder and the updated UMS software. Up until 6.5.1 this was all running just fine. It has effected the last 2 updates 6.5.2 and 6.5.3. Some sort of fix is needed.
Sami32
Re: Running time.
Post by Sami32 »
Thank for confirming that, it's effectively a bug that need to be fixed. I have a good idea from which commit come this issue. I was waiting more informations from users...
It's in the top TODO fix list ;)
Could you post a MediaInfo text report from one of your problematic MP4 video files ? Thanks.
Chalkiejim
Re: Running time.
I don't know what your asking me to do, (media info text)?
Sami32
Re: Running time.
Post by Sami32 »
This sample will make it clear ;)
General
Complete name : C:\Documents and Settings\Philippe\Mes documents\Téléchargements\UMS Video Testing Suite (20150121)\MP4-H264-AACHE-2ch.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom/avc1)
File size : 4.38 MiB
Duration : 11 s 562 ms
Overall bit rate mode : Variable
Overall bit rate : 3 175 kb/s
Encoded date : UTC 2015-01-21 04:36:31
Tagged date : UTC 2015-01-21 04:36:31
Video
Format : AVC
Format profile : High@L4
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 11 s 427 ms
Bit rate : 3 015 kb/s
Maximum bit rate : 4 157 kb/s
Width : 1 920 pixels
Height : 816 pixels
Display aspect ratio : 2.35:1
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.080
Stream size : 4.11 MiB (94%)
Writing library : x264 core 144 r2525 40bb568
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=23.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Color range : Limited
Matrix coefficients : BT.709
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : HE-AAC / LC
Codec ID : 40
Bit rate mode : Variable
Bit rate : 192 kb/s
Maximum bit rate : 204 kb/s
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 kHz / 24.0 kHz
Frame rate : 23.438 FPS (1024 spf)
Compression mode : Lossy
Stream size : 269 KiB (6%)
Encoded date : UTC 2015-01-21 04:36:07
Chalkiejim
Re: Running time.
I know what you mean now. I didn't know it was called that. Before I send this info to you something has changed. There was a Java update, (Java 8 update 121), the other day which I installed. I always have trouble with Java as I run a 64bit pc with 32bit IE. It never knows which version to install. Anyway I forced it to install the 32bit version as that is what it recommended as I run the 32bit IE. Would you now it, UMS works fine now. All my running times are showing correct on all formats. Weather UMS doesn't like the 64bit Java version or not, I don't know. Maybe Java had changed something in the previous updates that they had changed back, who knows. All I can tell you now is that my UMS is running how it should. If you want anymore info, let me know. Thanks again.
Sami32
Re: Running time.
Post by Sami32 »
Thank you for letting us know.
But i suspect that the errors i saw in your log are still there...so i'm interested by one MediaInfo text log of a problemtic MP4 video file (i'm not an english native, so that could explain... ;) )
If you could produce a new trace log as before, that i can make sure that errors are still there, it'll be nice.
Thank you.
Chalkiejim
Re: Running time.
Here is the trace log that you requested. I have used the same MP4 file as before so you can get a good comparison. I don't know how to get the media info for you, sorry.
(177.23 KiB) Downloaded 482 times
Sami32
[SOLVED] Running time.
Post by Sami32 »
No more this error in your log, that's good for you ;)
In the first log you was using "Samsung C/D Series" renderer and in this one your forced the "LG LA6200" renderer, on a different TV it seem, that force stream everything, that's why you don't experiment this issue anymore.
It's good for you, but the UMS bug stay here...
Did you already installed MediaInfo ? https://mediaarea.net/fr/MediaInfo/Download
You right click on a (ex) problematic MP4 files and choose "MediaInfo". From there you can copy the informations and paste it here.
EDIT: Please, could you edit your first title's issue and add "[SOLVED]" in front of your title, as i did ?
Thank you.
