UMS randomly skipping when transcoding .mkv
My UMS set up is working perfectly on both of my PS3's and my PS4, aside from one issue - I am getting a random skip in certain .mkv files, and only .mkv's. Skip is fully reproduceable, as in it will happen at the same time in the movie (happening on various movies). The skip will jump approx 2/3 of the movie, but if I rewind to that point, and play, it plays fine. Anyone else getting a similar error? Running UMS on CentOS7 all latest updates.
Re: UMS randomly skipping when transcoding .mkv
viewtopic.php?f=9&t=556
If you can add a copy of your MediaInfo export file about the problematic video, after having configurated it with "Text" in the View Tab and "Debug" and "Advanced mode" and "Full parsing" in Debug tab, that will be very helpful as well. See an example below:
