Audio is lagging when streaming to PS3
So, as the title suggests, when I stream some files to the PS3, the audio lags at differing rates. I haven't been able to determine if any types of files are worse than others, but the debug file attached is for a video where the audio was the worst it's been, almost a full second out of sync with the video. It's always behind though.
Thanks in advance for your help.
Re: Audio is lagging when streaming to PS3
I don't know how I forgot to do that. I put it as an attachment but it didn't stick. Here it is (again). Thanks.Sami32 wrote:I guess that you have forgotten to join your log...
Changing your name on the forum or not saying hello will not make your request be considered faster or better, if not at all...
You didn't named the video file that you tested. That should help pointing at your issue faster without going to search through all the full log.
I didn't change my name in the forum. I don't know why you'd think this. And I'm sorry for not saying "hello" but I did try to be polite with my request, did I not?
I didn't realize I needed to name the video file as well. My apologies for that mistake. It was the "Gennady Golovkin vs. Daniel Jacobs" file. I believe it's the only file I would have in the log since I restarted UMS before making the debug file. In any case, that's its name.
UPDATE: I played another file last night that was particularly bad and noticed that both it and the other one I mentioned above were both MP4 format. So, MKV files have a slight lag but MP4s are much worse, it would seem.
I saw in another thread that it might have something to do with codecs? I installed my OS recently and used the CCCP codec bundle.
Any help would be very much appreciated.
