UMS 5.2.3
UMS 5.2.3
Earlier this week I had to carry out a 'clean install' on my iMac and am now attempting to rebuild the machine as previous with apps, etc.
I am using OS 10.6.8 with Java 6 which (I think) means that I should be using UMS 5.2.3.
I used the earlier version without any problems previously.
Is there any way that I can retrieve this earlier version?
Cheers
Cheers
Re: UMS 5.2.3
Thanks, Sami32
Yes that is the correct link for my OS - I had already worked out how to get to the sourceforge link by searching through UMS and had loaded the software before reading your posting.
Everything is working as before
Cheers
miklos
Cheers
miklos
