UMSBuilder 1.5 is released
Post by SubJunk » Wed May 22, 2013 5:04 pm
General:
UMSBuilder automatically builds the latest revision of UMS for Windows and Linux.
To use it, simply unzip UMSBuilder and run (double-click) Build.bat.
Note: This will build the program from potentially untested code, so while it should usually be OK there are no guarantees.
If you want stability, download the latest official release from our front page.
You can download it here
Changes since 1.4:
  • Updated Maven to 3.0.5, which:
    • Improves SSL support
    • Fixes build failure with JDK 1.7
  • Updated Java to 1.7.21, which:
    • Improves security
Ohsem
Re: UMSBuilder 1.5 is released
Post by Ohsem » Wed May 22, 2013 7:44 pm
Hi, thanks for the update.
Seems like I can't build it due to the program tries to download something from jgoodies website which is down by the time of this writing.
Any other solution for this?
Post by SubJunk » Wed May 22, 2013 9:17 pm
I guess just wait until it's back up, it should be up soon
