Cannot play DVD iso
salsolo
Cannot play DVD iso
Post by salsolo »
So it's time for me to seek help again :)
Using version 2.6.4 % 3.0.0.alpha I just found out I cannot play DVD iso files.
It seems Memcoder does not handle it correctly but if I need to use something else how do I force that automatically? I would expect if Memcoder can not handle iso something else should do it?
I have only attached logs from 2.6.4 as version 3 logs are the same.
..and thank you a great product :)
UMS 2.6.4
(1.03 MiB) Downloaded 453 times
Re: Cannot play DVD iso
What happens exactly?
salsolo
Post by salsolo »
Doh, sorry for forgetting something that basic :)
I get the error Content cannot be played (800288E1) on a PS3 running with newest FW.
I also tried it on my Sony BD player and get a file appears to be corrupted on that.
When going to the transcode folder I can only select Memcoder - shouldn't I be able to choose avisynth as well?
salsolo
Post by salsolo »
I finally figured out what the problem is :) :shock:
For some reason UMS no longer supports my regional codepage ..so anything in a library containing local letters (æ ø å in my case) will trigger this error including a folder :?
Is there anything I can do with configuration or is this simply broken in UMS? Both 2.6.5 and 3.0.0-a3 has this problem.
salsolo
Post by salsolo »
Just confirmed this still exists in a5 - any plans on fixing this?
2.4.2 Works fine with native letters but it breaks going higher :(
