Mkv subtitles don't show
a12r13
Post by a12r13 »
Hello guys, I use UMS 3.4.1 and I love this software.
I use it with a Samsung TV with SmartHub (I think the software name is AllShare - not sure).
I've just one issue : I try to read a mkv file with french subtitles, but they don't show... although I can see them when I play he file with VLC on my PC.
I suppose the issue comes from the subtitles parameters : I tried lots of changes after reading threads on this forum, but it never worked.
I attach a logfile including opening of the movie
I also attach a screen copy of my subtitles parameters.
And last I attach a screen copy showing the subtitle mentioned by VLC while reading the mkv file.
If you need anything else please tell me.
Thank you in advance for your help.
subtitles list showed by VLC
mkv subs.png (12.24 KiB) Viewed 6313 times
subtitles transcoding parameters
UMS param.png (41.17 KiB) Viewed 6313 times
UMS logs
(25.04 KiB) Downloaded 453 times
a12r13
Re: Mkv subtitles don't show
Post by a12r13 »
Any help someone ?
Thx
pen
Post by pen »
Is it an MKV file with embedded subtitles or do you have external subtitles (separate file)? I guess the former?
Have you tried to use the #TRANSCODE folder and chosen to play with subtitles? Is there such an option visible?
I do also have issues (see Linux threads) but probably not the same as you since in my case UMS is at least trying to transcode the subs. Anyway, if your Samsung is A,B,C or D series, then it can most probably not render MKV embedded subtitles so you have to make UMS transcode somehow.
Pen
a12r13
Post by a12r13 »
Hello
the subtitles are embedded in he file.
I did not try to use subtitles files but I think I'mgoing to try that since I can't find any other solution.
I'll post some news when I will have tried.
Thx.
