language selection broken for avi's
Jeymz
Post by Jeymz »
Hi there,
the mencoder engine behaves in the following way:
Inside the #--TRANSCODE--# folder:
When I select German: I get no sound at all.
When I select English: I get the German audio track.
This is only for avi-files. mkv's are fine.
You told me that ffmpeg is going to replace mencoder. So if ffmpeg will support language selection soon then, personally, I don't care about mencoder anymore. However I imagine that it still might be worth fixing this in mencoder, because it probably isn't a big issue and mencoder probably still is more reliable.
Thanks for all your efforts,
Jeymz
Re: language selection broken for avi's
Post by Jeymz »
Here's some debug info.
Default UMS configuration except for network interface and shared folder.
Also I just checked the newest PMS 1.60.0 release and it behaves the same.
However I compiled UMS from SVN (using instructions I found in the release section) and it behaves a bit different (reported UMS version: 1.4.1):
In this case both language selections give me the German audio track.
And by the way: With the SVN version tsMuxeR only offers German language on an mkv file, while UMS 1.3.0 tsMuxeR shows both German and English options.
UMS_debug_log_example_avi_german.txt
(13.59 KiB) Downloaded 554 times
UMS_debug_log_example_avi_english.txt
(13.03 KiB) Downloaded 583 times
mediainfo_example.avi.txt
(2.05 KiB) Downloaded 542 times
