Documentation?
Documentation?
Is there any documentation for UMS, that I could read up front? Thanks!
Re: Documentation?
http://www.universalmediaserver.com/faq/
and
https://github.com/UniversalMediaServer ... erver/wiki
and if you are looking for info on plugins that will work with UMS
http://www.universalmediaserver.com/plugins/
and
Re: Documentation?
Thanks. Sounds like this tools is for people who enjoy playing in the technology, as opposed to people who just want to set up a media server and enjoy it. Yes? Or does someone believe otherwise?
Re: Documentation?
A little bit of both...
Universal Media Server Wiki!
Re: Documentation?
If you are not into tinkering and tweaking with all the options that UMS has to offer, you can just start doing a clean install with default settings; that should suit first timers.VLM wrote:Thanks. Sounds like this tools is for people who enjoy playing in the technology, as opposed to people who just want to set up a media server and enjoy it. Yes? Or does someone believe otherwise?
Only make sure your rendering device that's actualy playing the media is on the list of supported devices.
If your UPNP device is not supported, you have to create your own renderer configuration file.
There is information on how to do that, but if you get stuck, you can always search for help via the renderers section of the forum.
Good luck and have fun!
