DTS Problem on Sony Bravia
T4keru
Post by T4keru »
Hello people,
I've recently gotten myself a Sony Bravia KDL-50W829B TV and started messing with DLNA. First I've tried PS3 Media Server as it's the most known one and it worked fine except for files with subtitles. Anyway, through some googling I came up with Universal Media Server and installed it. It was working so much better with the subtitles files and also seems to be overall better and more stable.
The one thing I can't get to work (and it was working with PS3 Media Server) are files with dts tracks.
So far I've tried:
  • * Remuxing
    * Removing the DTS (File plays normally then)
    * Enabling "Keep DTS tracks"
    * Enabling "Encoded audio passthrough for AC-3 and DTS"
    * Disabling "Automatic resampling"
The file "pretends" to play on the TV but it gets stuck at 0:00:00 and never actually starts. When I pause and resume, the time is running but no video is visible and no audio is playing. I've also tried different files (much smaller ones), as soon as a DTS is involved it won't play.
Thanks in advance for the help.
The file is:
General
Unique ID                      : 251310970719096152386709407189864148613 (0xBD10BB7DA7ADF50CAAE6AB01ACBDEE85)
Complete name                  : D:\DLNA\File.mkv
Format                         : Matroska
Format version                 : Version 4 / Version 2
File size                      : 12.2 GiB
Duration                       : 1h 58mn
Overall bit rate               : 14.7 Mbps
Encoded date                   : UTC 2014-03-21 20:13:35
Writing application            : mkvmerge v6.7.0 ('Back to the Ground') 64bit built on Jan  8 2014 15:10:52
Writing library                : libebml v1.3.0 + libmatroska v1.4.1
Video
Format                         : AVC
Format/Info                    : Advanced Video Codec
Format profile                 : [email protected]
Format settings, CABAC         : Yes
Format settings, ReFrames      : 4 frames
Codec ID                       : V_MPEG4/ISO/AVC
Bit rate                       : 13.2 Mbps
Width                          : 1 920 pixels
Height                         : 1 080 pixels
Display aspect ratio           : 16:9
Frame rate mode                : Variable
Original frame rate            : 23.976 fps
Color space                    : YUV
Chroma subsampling             : 4:2:0
Bit depth                      : 8 bits
Scan type                      : Progressive
Bits/(Pixel*Frame)             : 0.266
Writing library                : x264 core 140 r2377 1ca7bb9
Encoding settings              : cabac=1 / ref=4 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=esa / subme=9 / psy=1 / psy_rd=0.90:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=96 / keyint_min=9 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=0 / bitrate=13200 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=40000 / vbv_bufsize=30000 / nal_hrd=none / filler=0 / frame-packing=3 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.80
Default                        : Yes
Forced                         : No
Audio
Format                         : DTS
Format/Info                    : Digital Theater Systems
Mode                           : 16
Format settings, Endianness    : Big
Codec ID                       : A_DTS
Duration                       : 1h 58mn
Bit rate mode                  : Constant
Bit rate                       : 1 509 Kbps
Channel(s)                     : 6 channels
Channel positions              : Front: L C R, Side: L R, LFE
Sampling rate                  : 48.0 KHz
Bit depth                      : 24 bits
Compression mode               : Lossy
Stream size                    : 1.25 GiB (10%)
Language                       : English
Default                        : Yes
Forced                         : No
Text #1
Format                         : PGS
Muxing mode                    : zlib
Codec ID                       : S_HDMV/PGS
Codec ID/Info                  : The same subtitle format used on BDs/HD-DVDs
Language                       : English
Default                        : Yes
Forced                         : No
Text #2
Format                         : PGS
Muxing mode                    : zlib
Language                       : Spanish
Default                        : No
Forced                         : No
Text #3
Format                         : PGS
Muxing mode                    : zlib
Language                       : French
Default                        : No
Forced                         : No
Menu
00:00:00.000                   : en:1 - 0:00:00
00:04:27.559                   : en:2 - 0:04:27
00:11:12.088                   : en:3 - 0:11:12
00:16:27.820                   : en:4 - 0:16:27
00:20:11.836                   : en:5 - 0:20:11
00:26:52.319                   : en:6 - 0:26:52
00:31:02.944                   : en:7 - 0:31:02
00:36:10.627                   : en:8 - 0:36:10
00:43:36.614                   : en:9 - 0:43:36
00:50:14.511                   : en:10 - 0:50:14
00:54:59.421                   : en:11 - 0:54:59
00:59:54.049                   : en:12 - 0:59:54
01:09:57.735                   : en:13 - 1:09:57
01:13:59.018                   : en:14 - 1:13:59
01:19:12.247                   : en:15 - 1:19:12
01:24:17.386                   : en:16 - 1:24:17
01:33:00.825                   : en:17 - 1:33:00
01:38:55.555                   : en:18 - 1:38:55
01:44:41.609                   : en:19 - 1:44:41
01:48:38.303                   : en:20 - 1:48:38
(42.17 KiB) Downloaded 367 times
