Showing chinese characters in UMS
I have installed UMS on Ubuntu 14.04 using the headless approach. My UMS can stream and see all folders which are in roman characters. However, those folders and file names which are in double characters, like chinese cannot be shown via the media renderer (including iOS, Android devices and the PS3). I've physically viewed the folder from SSH sessions and the folders show the right chinese names, but when viewed via the media renderer, the folders are just missing.
Hence, how do I configure or install additional chinese character support for UMS so that it shows in all media renders.
Thanks,
Thanks,
Re: Showing chinese characters in UMS
Same problem here.
The log shows "filename could not be parsed. It will be hidden"
If I change it back to English file name and path. Seems working.
It was working in PS3 Media.
i'm seeing weird characters in the ums interface itself with the french lang, go in the transcode settings for FFMPEG , i only saw it in there.
- garbledwordsffmpeg.png (54.27 KiB) Viewed 5990 times
Win 10 64bits
Qnap TS-212 2x3TB WD Red
Sony Bravia MN (my own conf)
