PS4 isnt found through UMS anymore
Hi guys,
This is my first post. I have searched your forum a lot but couldnt find any help so far.
I really hope you will be able to help me.
Please find the debug files attached to this post.
Thank you a lot for your help.
Best regards,
Menu
Best regards,
Menu
- (44.47 KiB) Downloaded 465 times
Re: PS4 isnt found through UMS anymore
Hi Menuchim, thanks for the logs. Can you please try older versions to see what was the last one that works? https://sourceforge.net/projects/unimed ... s/Windows/
I just had this happen as well, after a new java update. Literally just found out, so I'm trying to roll back java to see if that's the issue.
Ok, I figured out what happened. Its NOT a incompatibility issues with UMS.. Its Java's stupid auto updater. It "updated" my current java 8 install to a current java 7 install! Since I'm running the version of UMS that requires java 8, of course it failed connecting.
I manually installed the latest java 8 on my system and it over wrote the java 7 garbage, and restored ums functionality.
Idjits!
Idjits!
That's good news Gareee, so it's working normally for you on PS4 now? What about you Menuchim?
Hey,
I will try that today as I am currently not at home and post my feedback then.
Thank you for your hint
Regards,
Menu
Regards,
Menu
tried it with no effect. For whatever reason, it works when turning off my firewall eventhough my TV gets recohnised perfectly
Any ideas?
Regards,
Menu
Any ideas?
Regards,
Menu
