[Solved] playing video problem
I just updated to the latest version of UMS everytime I play a video the video would play at 1.5 the speed and the audio is 1-2sec behind.
after a few moments the audio plays while the video is at a stand still. I tried to change settings and it did not help, the previous version I have
i did not change any settings at all that i know of.
- (32.32 KiB) Downloaded 360 times
Re: playing video problem
ok correction, its just mkv files.. I was checking and it plays The Lorax in mp4 with out a problem yet when I play the big bang theory episodes in MKV it gives me the error =(
Yeah I think we've seen problems with those episodes before (old thread viewtopic.php?f=9&t=385) but the guy disappeared so we didn't fix it.
What happens if you go to the Transcoding Settings tab, select "MEncoder" on the left, then untick "Remux videos with tsMuxeR"?
no change.. now ums is listing the folders all wacky. UMS>C:>The Big Bang> then it shows C: again > Seasons folders> then the episodes...
ps3 media server works with the videos .. idk . where can i get UMS2.5x version at?
I just tested it and the file works fine for me when I have unticked "remux with tsmuxer". Make sure you click save after you untick it too or it won't work
As for the other thing, that sometimes happens if the PS3 has been on for a while, just restart it
I'm having a similar problem, but only with some MKV files of Doctor Who. The first two episodes works fine, but I can't play the third on my TV. I just get a black screen... The same happens with some movies too.
